Joe Gentile
New User
I have a Case 530CK Loader Backhoe. The serial number (which I can't seem to locate to find the year of the Tractor) is; 8215105. I want to change the Torque converter oil as well as the Transmission fluid in the Tractor. I do see two what appear to be large 1 1/4" plugs under the machine in the locations of what I think is the area to drain the fluid from, but not sure. Also need to know where the filters are located in order to change them also. How much does it hold,and where do you refill the system? Type of Oil? Any help would be greatly appreciated. Thank you! Also, if you know where I can find out where to go to identify my Tractor year using the serial number,this also would be great!
