Case Tractors Discussion Forum |
Case 830 ComfortKing
Author |
[Modern View] |
Andy Sargent
04-05-2011 20:10:13
1969 diesel Case 830 Comfort King case-O-matic with case bucket has developed a slow and weak hydraulic response. Hyd. fluid was tan and I assume water contaminated, changed fluid, no improvement. Am I looking at a new pump, or do I look somewhere else first? had this tractor from new and use it somewhat regularly.
Mike in Mn.
04-07-2011 06:19:06
Re: Case 830 ComfortKing in reply to Andy Sargent, 04-05-2011 20:10:13
My 830 Comfort King did that about 15 years ago, it was the pressure relief valve. There was an update kit that I installed and it"s had 1500 psi ever since. Have no idea if there is anything available anymore. Stick a 2500 lb. pressure gauge in one of the remotes and see what you have.
andy sargent
04-07-2011 06:28:25
Re: Case 830 ComfortKing in reply to Mike in Mn., 04-07-2011 06:19:06
THANK YOU FOR THAT INFORMATION, I WILL SEE WHAT I CAN FIND. I APPRECIATE YOUR HELP!
Case Nutty 1660
04-06-2011 01:41:23
unless you had enough water in the oil to cause pump damage(can happen just not very often) your problem is in the hyd valve
andy sargent
04-06-2011 04:30:16
Re: Case 830 ComfortKing in reply to Case Nutty 1660, 04-06-2011 01:41:23
Thank you for the reply. I will look into that and see what it requires. Do you know if this means replacement or maybe just a rebuild?
Case Nutty 1660
04-06-2011 05:59:17
Re: Case 830 ComfortKing in reply to andy sargent, 04-06-2011 04:30:16
usally just a rebuild but be prepared parts are a little pricey, if you know some one with a flow meter it will help you in repairing your system cnt
andy sargent
04-06-2011 15:58:38
Re: Case 830 ComfortKing in reply to Case Nutty 1660, 04-06-2011 05:59:17
Again, thank you for the response. I am a 'I like to do it myself, but have no experience' kind of guy and will probably search out a mechanic or tractor guy to help me out. Too much potential for screwing it up on my own.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
