1957 400 Super Diesel Hyd Pump
av8or4951
Is the hyd pump on a 400 super diesel able to be blead? Is it even nessary? when I rase my three point up it stops than falls down. Is there a way to get parts to rebuild?
Thanks in advance,
M. Linsley
Don't think it's the pump. Could be leaking by within the cylinder, & they can be re-built, or it could be the valving.
(quoted from post at 16:16:41 03/31/11) Don't think it's the pump. Could be leaking by within the cylinder, & they can be re-built, or it could be the valving.
It's a brand new Delavan Hyd Ram, I had to replace the old ram not the correct one and leaked from the case where the fitting went in.
Ok, I have found the problem....... me :oops: whan I re-atached the hoses I put them on opposite the way they came off, figureing when I lift the lever it should go up and vice versa never thinking about the one way valve :oops: Problem found Operator error.
shamefully,
M. Linsley
