Anonymous-0
Had this fuel pump rebuilt 10 years ago because it was leaking fuel in the oil ,, now i suspect it is doing it again . did not contain water or antifreeze when i changed the oil . oil level was up on the 800 by a couple quarts when i went to wake the Fine Lady up after winter hibernation , i guess i shoulda turned the fuel off .. As far as I can tell? There is no place on These pumps to check or change oil ?, I always supposed they oiled from the Engine .. does anyone know if it is possible to make repair without pulling this pump and risking the need to retime ( don't wanna go thru thathale again).. thanx jh
