Was just wondering if any one has worked on the new mccormicks txm120. The tractor will just stall and will not start. Crack a few injectors to bleed the system and she fires right up. Any one else had many fuel troubles with these tractors. Also seems that we are puting a fuel pump on it every year. Your thoughts? Ranch
Re: Mccormick txm120 fuel pumps in reply to ranchingelec, 03-17-2011 06:53:23
Yes probably is electric shut of. I will have to check the wiring. It is a neibours tractor, and he just comes over for help when the tractor quits. Always same story. tractor stalls bleed fuel system and it takes right off.
Re: Mccormick txm120 fuel pumps in reply to Ranchinelec, 03-18-2011 14:02:43
Which side of the injector pump do you have to bleed or is it both? Weak transfer pump? Had a speck of dirt fall over the hole in the tank once also, a fine wire up the line popped it out.
Today's Featured Article - Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well.
... [Read Article]
Latest Ad:
Would like to find hay table for a John Deere 700 or 750 grinder mixer
[More Ads]
