Help with Case 310B
Author |
[Modern View] |
OnagaCat
03-16-2011 12:32:12
This is a 1958 310B frontloader/backhoe without the backhoe mounted. It's a dual range. Starts and runs fine but the gears don't work at all. No amount of shifting the 4 speed gears, shuttle or low/drive lever does anything. No clashing of gears. The clutch pedal moves and the clutch rod that goes into the bellhousing moves but I feel no change in resistance nor is there any change in noise. The tractor has been sitting for a few years - is this the dreaded clutch rusting to the flywheel? If so is there any way to fix it short of splitting the tractor?
Steve from PA
03-17-2011 09:23:04
Re: Help with Case 310B in reply to OnagaCat, 03-16-2011 12:32:12
I had the clutch arm that works the throw out bearing actually break away at the end where the ball is o0ne time. This was on my 300. So I could not work the clutch but the pedal still worked. Maybe something like that could be the problem. Good luck, Steve
Joe (Wa)
03-17-2011 13:03:23
Re: Help with Case 310B in reply to Steve from PA, 03-17-2011 09:23:04
 Yes that happens. The knob can wear and break off or the yoke socket can wear through. That just negates the foot clutch function. The clutch remains engaged full time without the ability to disengage externaly. The other symtom is the shaft does not turn. Joe
Joe (Wa)
03-16-2011 14:29:49
Drive shaft not turning and no spring resistance on clutch linkage? There is no single malfunction or broken part that can account for all your symtoms other than the pressure plate lever springs being depressed & seized in the disengaged position. I suppose this could be possible if the clutch pedal were locked down for a prolonged period plus rusting of the pressure plate. How likely is that? Joe
Adirondack case guy
03-16-2011 13:48:42
Your clutch is not stuck to the flywheel or pressure plate. If so you would not be able to stop the tractor from moving when in gear. I would guess the center of the clutch disc is sheared, or the linings are stripped off the disc. Bad News!! You gona have to split her. Not a lot of fun with the loader on it. No hand clutch on that setup so thats out.
Case Nutty 1660
03-16-2011 14:06:06
Re: Help with Case 310B in reply to Adirondack case guy, 03-16-2011 13:48:42
you said it better than I and maybe we are twins as I also thoiught of the hand clutch but like you said with a shuttle thats out,did you see the 930 twin to yours I posted??? CNT
Adirondack Case guy
03-16-2011 14:28:43
Re: Help with Case 310B in reply to Case Nutty 1660, 03-16-2011 14:06:06
Yes I saw it. Paint is as yours, my grill screens are not dented, but the bottom back of the fenders have the usual dings. It's a hand clutcher also, with 18.4x34s. and PS. Hopeing to get it together this summer. I need to win the lottery. Had a long time customer call me a bit back and wants me to buy his Big 411 NF and his 711B NF at a really good price. If I buy them there goes the budget for the 930. PS both these tractors are still daily workers.
Case Nutty 1660
03-17-2011 05:24:30
Re: Help with Case 310B in reply to Adirondack Case guy, 03-16-2011 14:28:43
if your like me you will buy the new addition's as the 930 looks snug where its at,,,,for now by the way how many is to many?? me and the little lady have Two different ideas on that....CNT
Case Nutty 1660
03-16-2011 13:44:25
If the clutch rusted to the flywheel it would only grind as the tranny input shaft would not stop turning I would guess something is broke,center of the clutch plate,shaft,gear, shifting fork ect,,,sounds like you will have to split it, good luck CNT
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
John Deere 820 tractor in very good condition.2 owner tractor with original rear tires. 715 853 3669
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
