Ok this is what I found out today on using the A7634 stat on prior serial number 8060853. The book says to use 1 A7635 housing, 1 A7636 seal, A7637 ring, A7638 ring with brass screws, and A7639 gasket which is used with both housings. I did forget to run the housing number A7635.
Part numbers A7636 and A7637 changes to 310947r91 and that number is still available from CNH and so is thermostat A7634. Part numbers A17636 and A7638 are still available from Parts Depot. Locator showed Ritche Implement having 3 of the A7638.
I think you can reuse the old housing if you drill the holes for the ring. I ordered a thermostat from CNH to see what all comes with it. Don't know if this will win you a free meal or not Mel.
caseman-d
caseman-d
