i was trying to get unstuck yesterday and was rocking back and forth and then lost reverse. All foward gears worked and i got it in the garage. I pulled the top cover and found no exploded gears? the Reversed shifiting fingers are attached to the rail and the setscrew is tight? i put it back together and it is the same? when shifted into reverse it just makes grinding noises like the reverse idler is not slideing far enough foward. i pulled the cover again and slid the reverse idler in and held it with a long screw driver. pushed starter button with fuel shutoff pulled and the starter makes the tractor creep along in reverse. put it all together again and it is still just grinding? is there a way to adjust that shifting fork? seems like all i could do is heat it up the the torch and bend it foward but i hate to do that and it might not release what slid back then i will be stuck in 2 gears.here are some pics of the tranny and cover? help any ideas?
