Belt pulley VAC
How does the belt pulley shaft engage on my 49 VAC wide front there is no lever to throw it in, and it doesn't run when the PTO is in gear ,sure is strange to me. My 32 CC has it's own lever.
thanks Dick
There should be a bolt with a square head on the top of housing. Loosen bolt then either pull pulley out or push it in,I can not remember which. Then tighten bolt and start tractor and it should run.Pulley should slide about an inch. Good luck Scott
Scott is exactly correct. I've uploaded a graphic of the mechanism he described. After loosening the bolt, just push the pulley in and retighten the bolt. The next time you let your clutch out, the pulley will turn -- assuming the gears inside your tractor are OK.
Thanks guys, I had a feeling that would be the answer.This Discussion Board is the greatest, with a great group of old tractor garu's.
Thanks again, Dick
