I got my little pickup stuck yesterday and I went home and got the tractor to pull it out, I had to pull it up a hill but it wasn't overly steep. I hooked the chain up, put it in first gear and started pulling, we started moving but I think the clutch was slipping, it has a hand clutch and i tried pushing harder on that lever which seemed to help for a second or two while I was pushing really hard but didn't solve the problem. Then all of a sudden it hooked up, the front tires came off the ground and up the hill we went. It's fine when your just putting around on it but once I tried to take off in fourth and the belt pulley starts turning, the engine kinda pulls down but the tractor dosent really go. Is this the clutch slipping or could the linkage need to be adjusted, if it can even be done.
