Re: va timing in reply to chris8131, 01-16-2011 17:40:24
As Mackdog said, remove the #1 spark plug and put your finger over the spark plug hole as you slowly turn the motor over by hand. Make sure you rotate it the correct direction. Once you find the compression stroke either shine a light in the spark plug hole or put a thin screwdriver in the hole and continue to slowly rotate the motor until the screwdriver stops moving up. This will be top-dead-center. Then like Mackdog said you can remove the distributer cap and locate #1 one wire. The rotor should be pointing to #1 at this time. If not you will need to rearrange the spark plug wires or pull the distributor and align it so that the rotor does point to # 1. Make sure that you match the spark plug wires with the direction that the rotor turns.
number one is the one at the front near the radiator, you can tell it is on the compression stroke which is the one it fires on by removing the plug turning the motor over with you finger over the hole and feeling for compression, also remove the dist. cap and the rotor button should point to the wire going to the number 1 plug.
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
