Case Tractors Discussion Forum |
Case/Bosch injector pump
Author |
[Modern View] |
Justin Wheeler
12-27-2010 20:31:11
I have a 1960 730 diesel. The tag on the pump says to drain and add crankcase oil, my manual is very vague when it comes to the pump. I did some diggin around and read several times that the cap on top of the pump is where u fill it and the plug towards the bottom is where u drain it. but when i look in the top or drain it all i get is some really nasty smelling diesel, NO OIl??? do I have a bad seal that is letting diesel into the governor housing? any info on this pump is greatly appreciated. Justin
mEl
12-30-2010 04:11:59
Re: Case/Bosch injector pump in reply to Dutchman, 12-27-2010 20:31:11
Someone else reading this will probably give an answer, Is there a plug on the rear square cover, if so that may be the level plug. Anyway, you can of course put to much in but if that tube I told you about is open it will only allow the pump to retain the proper amount, the rest will drip out to the proper level.
mEl
12-29-2010 04:00:10
Re: Case/Bosch injector pump in reply to mEl, 12-27-2010 20:31:11
The very earliest 730s and 830s were equipped with the pump that requires servicing. If your 830 has a fitting coming from the engine block to a fitting on the injection pump it does not require anything except regular servicing of the engine oil. My 830 and I suspect his 730 were the ones with the aircleaner mounted on the side of the tractor and had what we call the Lo profile tinwork, and eagle hitch. mEl
Justin Wheeler
12-29-2010 19:58:30
Re: Case/Bosch injector pump in reply to mEl, 12-29-2010 04:00:10
OK i feel much better about it now. Thanks mEl which on the screws or plugs on the pump is the fill level plug to tell when oil is full? Thanks again.
michaelsp230
12-28-2010 13:56:12
Re: Case/Bosch injector pump in reply to Justin Wheeler, 12-27-2010 20:31:11
my 830 has a oil line that feeds the pump so i don't have to change the oil in my pump . right ???
mEl
12-28-2010 03:47:28
Re: Case/Bosch injector pump in reply to C. Amick, 12-27-2010 20:31:11
No you do not have a bad seal, just the results of the pump not being serviced. The plungers in the pump have a small amount of natural leakage and that is why the pump has liquid the consistency of fuel. Even with new fresh engine oil the dilution process will start over again as soon as the engine is run. If you will notice there is a small pipe that comes down to a bracket on the pan flange with a loop in it, that is a drip tube and allows diluted oil to leave the pump so it does not get overly full. Change the oil and refill it and then run it a bit and redo it to flush pump an extra time then when ever the oil is serviced in the engine should be sufficient. My 830 was the same as yours when I bought it and the oil still gets thin between changes, also I'm sure the plunger fit has somewhat worn over the years and caused dilution to be more than when the engines were new. Newer engines that lube the pump from the engine oil are still leaking just like ours but the fuel just goes into the engine oil and is not seen as ours is. mEl
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
