Author |
[Modern View] |
Paul A Young
11-29-2010 19:41:44
Some time back my brother Joe posted out here asking if anyone had one of these drawbars.A couple of you responded having one,and a few after seeing it wanted one.I am trying to find dimensions on these so I can make a few.Any help would be appreciated,thanks Paul , Also if anyone would want one let me know.
Paul A Young
11-30-2010 19:04:27
Re: Eagle hitch drawbar in reply to Paul A Young, 11-29-2010 19:41:44
Thank you to all responses!I'll be anxiously awaiting an e-mail with more measurements.Maybe get a few made before christmas.
Adirondack case guy
11-30-2010 18:05:40
Hay guys I will get a drawing together in more readable form than before. I will e-mail the drawing to the several of you that responded this coming weekend.
Bohemian32
12-02-2010 21:17:46
Re: Eagle hitch drawbar in reply to Adirondack case guy, 11-30-2010 18:05:40
Please add me to your email list of dimensions. Dad built one years ago, and I am sure that it is still around somewhere, but I just can not seem to remember just where it was last stored.
C. Amick
12-02-2010 19:26:22
Can you add me to your email list to receive a copy of the drawing. I have a Case 300 that it would work on.
Adirondack case guy
11-30-2010 16:45:41
 Here it is again. It's still on my 57 300. I use it all the time to move my trailers and pull logs in the woods when I cut wood for heat. It will fit any eagle hitch Case tractor and many more floppy armed tractors by changing cap screws in the end of the round shaft to drilled pins for linch pins. You will need good lateral stablizers though.I can provide you with a better drawing than I did in my original post if you would like. E-Mail is open
hoosierboy
11-30-2010 17:09:44
Re: Eagle hitch drawbar in reply to Adirondack case guy, 11-30-2010 16:45:41
Thats a really nice looking Case, must be more fun than a new one.
Paul A Young
11-30-2010 16:38:07
I found the old post as well. Thanks.The problem is with the dimensions,the print is too small to read the verticle bars mesurements,distance apart and where the horizontal pipe is attatched to vert.bars
JGarner
11-30-2010 18:06:41
Re: Eagle hitch drawbar in reply to Paul A Young, 11-30-2010 16:38:07
Paul, the original file was a .jpg. When you open it down at the bottom of the page you will see a little magnifying glass with a plus in it. Click on this until the print gets large enough to see, that is what I did. Jim
jay-eye-see
11-30-2010 07:44:09
 I'm not sure but think it was "Adirondack case guy" that posted this pic and some dimensions. I saved the pic (as you can see) and carefully wrote down the dimensions and still have them somewhere. Let me know and I can see if I can send them
mEl
11-30-2010 07:13:53
Re: Eagle hitch drawbar in reply to nitrous, 11-29-2010 19:41:44
Bruce, he is referring to an Eagle Hitch drawbar that used the three points and had a drop piece on it with a drawbar plate and hole for the pin, it could be raised and lowered to suit the application and was quite handy. He is not referring to an underbelly standard type drawbar. mEl
Bruce Nelson
11-30-2010 06:58:08
Drawbar for what model tractor and which drawbar? DC's, for example, had more than one drawbar with the Eagle Hitch.
