Author |
[Modern View] |
C. Amick
11-18-2010 17:37:32
Has anyone ever used Penetro 90 penetrating oil, see link below? I've used PB Blaster quite a bit and I know it works better than Liquid Wrench. I've also read that some think Kroil is better than PB Blaster.
Ken Ind.
11-21-2010 08:25:17
Re: Penetrating Oils in reply to C. Amick, 11-18-2010 17:37:32
Iv used both and I believe it user preverance. They both work equally as far as I am concerned Good luck Kenny
mEl
11-21-2010 04:19:27
Re: Penetrating Oils in reply to nitrous, 11-18-2010 17:37:32
I agree with Lurch, when you find something you can't keep in a can you've got the ultimate!!!! Years ago, Bowman products distributed a product named "Du All" It worked better than anything else at that time but I have not seen it for years as we no longer use their products at work. mEl
Jim McVay
11-20-2010 19:20:55
My dad has been using GIBBS penitrating oil with good sucess
Lurch.
11-20-2010 18:45:10
Fuel oil is as good as most boughten junk. If all those potions are so good at penetrating metal and iron, How come they all stay in a TIN can???
zach81
11-19-2010 14:56:00
I use a combination of Kroil/PB Blaster mixture. Works great.
Allan from PA
11-19-2010 06:35:42
Found a Product from CRC called Knock'er Loose that works really good. Allan.
j heitkemper
11-19-2010 11:27:19
Re: Penetrating Oils in reply to Allan from PA, 11-19-2010 06:35:42
I use Pb blaster to shake it loose , followed up by wd-40,, really slicks up nice , Not TOO SURE , But some kinda chemical reaction occurs creating some heat...
Gene Dotson
11-19-2010 04:48:05
Best penetrating oil I have used is Torq-11 from Kimball Midwest. Bought a box item from tractor sales auction that contained 2 cans of this. Worked really great. Now just have to get some more... Gene
rbradk
11-19-2010 02:11:39
Have not tried that brand. Have used a product called Free-all. pricey but works very well. A notch up from PB blaster IMO.
Eric in IL
11-18-2010 20:09:51
I have used about half a can this summer. It seems to be pretty good stuff. For the really tough situations I still reach for the Kroil though. Schaeffers' chain lube is #1 on my list, really like it !
