Case Tractors Discussion Forum |
Paging DKase
Author |
[Modern View] |
karlh
11-09-2010 06:50:55
When you installed the loader valve on your 970. The line that you tapped into fed your remotes. Mine has been replaced with a rubber hose that is about wore out (where it makes the bend to hook into the remote valve) so I bought the metal one from case...I thought it would have rubber in the middle, but it came solid metal tubing. Was yours solid tubing and if so how did you plumb your valve? I was going to cut a chunk out and put fittings on both pieces to run a hose to and from the valve, but no one in the local area can flare tubing that large..... any suggestions?
caseman-d
11-10-2010 06:48:25
Re: Paging DKase in reply to karlh, 11-09-2010 06:50:55
Case used to always put a part number on one end of the hose (a little metal band). You may want to go onto the case web site and make sure you have the right tube. It surprises me how many times a customer will say, that looks like it and to find out it's not it. Hoses and tubes can always be a challenge at times. The newer ones are even worse. caseman-d
karlh
11-10-2010 11:24:29
Re: Paging DKase in reply to caseman-d, 11-10-2010 06:48:25
The p/n for the metal/rubber tube that came as orinigal equipment superseedes to the all metal tube....i think i may have found someone who can cut it and flare it so I can plumb in a valve
DKase
11-09-2010 10:28:43
That was 20+ years ago. I will look at the tractor and see if it brings back memories. Will try to post later tonight. DK
DKase
11-10-2010 06:06:40
Re: Paging DKase in reply to DKase, 11-09-2010 10:28:43
Sorry I did not get back to this last night. Got tied up in a FEMA meeting as a township supervisor. I looked this morning. The line from the pump on mine is steel to the cab mount, and hose from there. I had the fitting on the end of the hose changed to fit my valve. The line and the hose still have the original paint on them. If your new line cannot be modified I am sure a hose could be made for less $ than the line cost you. Good Luck DK
karlh
11-10-2010 09:33:41
Re: Paging DKase in reply to DKase, 11-10-2010 06:06:40
Thanks for your help I hope to have a valve on the tractor soon!
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
