A few months ago you wrote about installing a loader valve on a 970 "Sure there is. Did it on my 970. Plumb it into the line between the PTO valve and the original remote valve. The valve you install must have its own relief valve. I used a gresen loader valve with cable controls. I mounted the controls just to the right and above the 3 point controls. Looks factory from inside the cab. The valve itself is mounted to the side of the transmission just ahead of the right brake. I do not have a loader, but I needed 4 remote valves for several of the machines I pull. Its been on there for 25 years plus." Could you tell me how exactly you plumbed it? Did it have a power beyond port and what did you do with the out port? thanks!!
