Got my late 430 home tonite out of the weeds. Quite surprising it has the late brakes with Diff lock, DOM hitch. It was parked many years ago because of antifreeze loss. It has pencil injectors so I am presuming it has the wide flanged sleeve block. It has the very latest independant PTO unit, for all practical purposes it it is identical to the 470. I would like to talk to Adirondackcaseguy about helping me find parts to duplicate his turbo. It will need much TLC but there have been worse projects undertaken. It probably will end up a 207 as I have some hardware and the sleeves and pistons should be a drop in. I also have a warmed up to 207 specs Roosa pump to bolt on. ACG are you out there ????????????? mEl
