530 630 COM drawbar
mEl
Location
NC PA.
Fellow forumers, I usually try to avoid making the forum a commercial enterprise but I want this out to as many of you guys as possible, I am going over a 530 COM for my uncle and need the heavy COM drawbar, It may be the same as a 630 COM also. It is not the drawbar with the flat iron brace welded along the bottom , it is wider thicker and about 4 inches longer than a regular 530. This is for the very early 530 Eagle Hitch tractor. If anyone has one they would be willing to part with leave a post and we'll get together. Thanks for allowing me to do this guys!! mEl
The drawbar in question is slightly more than 38" (approximately 38 1/4") in length.
The non-COM drawbar for the 530 series is 3 1/2" shorter at 34 3/4".
Yes Thad, thank you for the courtesy of a followup call, I dropped the ball by not responding, Sorry. mEl
Thank you Joe, Maybe that will help someone out there identify one for us. mEl
mEl
I found one of the longer COM drawbars a while back for my 630, and learned about the different lengths at that time.... Good luck with your search. - Joe
MEL,
I have one for a 400-B which is COM. I see there is only one part number for 630, same as 530 COM. I do not know if this will help or not.
cnj152
cnj, thank you for posting that info, I will check but I think that is not as heavy as a 530 COM bar. mEl
