Picked up a 655 self propelled haybine this past weekend. Seems like a good machine except the blade is dull. Also picked up a plow earlier in the summer. Hope the pictures get in.
Re: Case Haybine in reply to RJKeith, 08-12-2010 15:07:52
We sold around 2 dozen 650 and 655 SP Haybines and a few less 950 and 955s The 655 was a good little machine. Very popular because you could drop the conditioned hay back into a swath rather than a windrow. You have to learn how to control them on steep slopes. The trim steer was great for following minor curves, but sharper turns required a bit of expertise with the levers when mowing on steep slopes.If you plan on mowing with it adjust the flotation springs so that you can lift each corner of the header easily with one hand. If you don't you will bend guards, break knives and wear out skid shoes, as well as affecting traction and handling. Also make sure that the stops for the tensioned conditioner roll is set so the two have a slight clearance and do not run in direct contact with each other. If there is no clearance you will destroy the rolls.
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
