mikefromiowa
I recently replaced my original light switch with a new one. I know it is wired correctly but the gauge showed 18 amps charging with the lights off. If I turn them on, she shows about 4 amps charging. About a week ago, the amp gauge was jumping all over the place, so after some looking, the cut out's contacts were burned. So I thought now is a good time to upgrade to a voltage regulator. Purchased a 6 volt positive ground (4 lug) from NAPA http://www.napaonline.com/Search/Detail.aspx?R=MPEVR850SB_0213353699. I rerouted the wire from the resistor light switch to supply the power to the switch from the "L" terminal on the VR. I removed the supply from the amp meter. You can see the remaining hook ups in the photo. I polarized the generator as per touching the "gen" terminal with the "bat" terminal. The tractor is now charging again, but its up to 18 amps at full throttle. If I turn on the lights, it drops down as before to about 4 amps. What would be allowing the generator to charge at that rate? I believe my amp meter is good, it is only a couple of years old and not a cheap one. My concern is that charging at that rate (if it is actually doing that) will cause the contacts to burn out on the VR. Can't seem to figure out how to post a photo here, but here is the uploaded link
https://photos.yesterdaystractors.c...5&Parameter=&mode=All&what=pieces
