630 Case-O-Matic PTO clutch repair
Rick M
New User
Are the 630 and 730 PTO's the same? I need the sliding sleeve in the PTO assembly and know where a 730 is being parted out. I don't have a parts book yet, only the repair manual. Thanks
There is not much in common between a 630 standard shift tractor pto and a 730 sorry to say. The COM tractors had a plate style over center clutch assembly of a different design entirely but may have had the same plates as a 730 but PN's would have to be chased to be sure, not much else in common. mEl
730 and 830 are close, as Mel said, part numbers must be chased. I have found that the closest thing to the 630 is the 511b for triple range and 611b for COM. I have a very early 630 dry clutch triple range and lots in common with 511b except engine and front end tin. I think rear fenders are common too.
Case IH parts site on line is a world of help for part number comparisons.
Jim
Do not count it out. Live power SC through 2290 use the same PTO clutch plates. I do not know much about the tractors smaller than the 700 so you will have to look up the part #'s.
Thanks for all the information. I checked the Case-IH parts site and got some part numbers and I think I have some parts tracked down. Thanks, Rick
