Company Logo (800) 853-2651 Shop Now
8 volt battery for the old CASE
Greenfrog
07-29-2010 07:10:00
I have CASE SC and DC. Seems like 6volt batteries are not as good as use to be. (I keep a little trickle charger on them at times) The antiques sit a lot, but seems like they need a little more "umph" when it comes to cranking. Can I put in an 8 volt Battery? Will it effect the electrical parts---the generator, voltage regulator, ignition, lights....?
LenND
07-29-2010 19:12:23
 Re: 8 volt battery for the old CASE in reply to Greenfrog, 07-29-2010 07:10:00
I agree with Randy in Nebra. If your tractor is in a good tuned up condition you only need a 6 volt. Don't matter if it old or new style. What are you going to do in a couple of years when 8 volt isn't enough? Go to 12 volt?
Greenfrog
07-29-2010 13:16:25
Thanks for info...all of you...Yes I have done the big 0 size cable already.
Randy in NE
07-29-2010 10:14:16
As the late Hugh MacKay was fond of saying: These tractors were designed to start on 6v and if properly maintained they perform as designed. One of the most important things is to have a heavy duty 6v cable. Do not try using a 12v cable. The 12v does not have as many wires as the 6v does. Power = current x voltage. If the voltage is 1/2 then the amps is going to be twice as much. Hugh always recommended using 0 or 00 gauge wires. I have had a 6v battery in one of my C's for at least 4 years. It doesn't get used much but enough to keep the battery charged. No problem spinning the starter. I am not saying anything against converting to 8v. You may have to replace the light bulbs with 12v bulbs. A friend did this on his Super H and the first time that he turned the lights on they blew. Each system is a little different. The manufacture of batteries is different for different classes of batteries. Sometimes a cheaper battery is exactly what you get, not always. Many factors involved.
Ken-Pa
07-29-2010 09:13:36
Yes 8 volt batteries work great . Just have the VR tweaked to put added charge back into batt from the gennny . I'v used 8 v for 10 yrs now in my tractors . Only replaced ( 1 ) headlite bulb in that time . HTH ! God bless
Hand Clucth
07-29-2010 07:30:48
Well if you can find an old 6 volt battery from the 1960s and remove the top and compare it to a 6 volt battery of today. You will find that the battery of today is a plate or two less than years ago. Yes, you can use an 8 volt and it will work much better and crank it over. The charging system will work since it olny has a cut out on the generator and the lights will also work. I run 20 tractors on 6 volt systems during harvest and I have special orderd 6 volt batterys with the full amount of plates in the past. The manufacture would not do it the last few years because the batterys with the full amount of plates lasted 6 years!
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo. ... [Read Article]
Latest Ad: Looking for a PTO shaft for a Vermeer 605L round baler. Mine was stolen. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
