In the process of restoring my 350 (351). I got a brilliant idea to add power steering to the old gal...... So I bought a system off of a 600B that the parts and service manuals all showed to be the same for the 351, 500B and 600B. After spending a ridiculous amount of money overhauling the torque motor, and then fabricating one of the steering shafts (thanks again Jim), I finally got the system "buttoned up" and working great. Great that is until I attempted to re-install the grill and hood. The following picture demonstrates the problem.
The pressure and return lines out of the pump stick out too far. Those lines won't allow the the side panels for the grill/hood to pull up correctly. The panel is at least an inch away from bolting up properly. I don't want to bend or cut the panel. Does anyone else have a pump/reservoir like the one in the picture mounted on a 300 series tractor? If so would you have a picture or two your would share that demonstrates how it is plumbed, and how the side panel is formed around the pump??? Thanks in advance for any thoughts or pictures anyone might have. - Joe
