54 Case VAC trans / rear end fluid
Anonymous-0
got my VAC running but now want to change the rear end fluid before I start using it. does ant one have a PDF of the fill and drain? I have found one drain directly below the seat and there is a fill on the left side below the dash, are these the only fill/drains on this tractor?? I don t want to miss anything while changing out fluids.
Thanks for any help in this..
K
the rear end fill for my '49 VAC is directly adjacent to the gear shift lever. I believe the fill for under the dash is for the hydraulic fluid for the eagle hitch.
