Anonymous-0
I have a 1394 Case/David Brown tractor. I pulled the tractor apart and found that there was a pin sheared in the fork arm that holds the throw out bearing. When I pulled the tractor back together, I could not get it started. Could this be from the splines in the clutch disc being out of line and jammed in the pilot bearing? Any advise on what to do?
Steve,
What about a neutral safety switch? Is it hooked up? I would like to think that if this does not work, you have maybe an electrical problem that may not totally be related to the repair that you performed.
