Kevin in Iowa
so I jumped on the 830 case this morning. It had been sitting for a couple of weeks. it started and I backed it up about 10 feet and it died. added gas and still nothing. So I had a set of plug wires and a coil so I changed them. Still nothing, the carb had been acting up last time I drove it, so I took that off and clened it up, and adjusted the float, still nothing. It looked like the plugs were dry when I removed them so I kept playing with the carb and I still cant get this thing to run. Finally I checked the spark coming out of the coil and it was a nice blue spark but at the plug it was very very weak..maybe the points?? cleaned them and also cleaned all the brass connectors inside the dist. Still nothing.. Could someone remind me on how to adj the points..its been a while.. points open??? and then set at .020 is that correct. sorry this is so long and thanks for the responses.. this is very agraviting..
also checked compression and they were all 150 psi
