mike in mo
im wanting to add a larger pump to my case VAI. i seen that the crank pully has 3 bolt holes in it and remember seeing a old power unit someplace that had a shaft running a fan off the crank pully in them holes. so i was thinking about running a pump off there kinda like the old ford loaders did but dont know what this shaft is called or how to make one up. i have a live pump on the motor now but dont like how it runs off the cam so im going to let it run the hydro steering and use the add on pump for the loader/3 point and remotes. i got a big idea and need all the help i can get to make it work. thanks up front guys
