Case Tractors Discussion Forum |
CASE SC GOVERNOR
Author |
[Modern View] |
Allen L
05-12-2010 06:57:55
Good Morning, I have a 1950 Case SC and recently found my distributor gears stripped off so i replaced the distributor. It started and ran great, My next step was to replace the carberator because the flange was broke. It started and ran a couple minutes and all of a sudden the governor seemed to jam up in the forward position. I now backfires as if the timing is off again. The governor seems locked up with little movement. Any ideas as to what I am up against? I read the service manual but was not much help. thanks for your time. Allen
L.Lamp
05-12-2010 19:18:19
Re: CASE SC GOVERNOR in reply to Allen L, 05-12-2010 06:57:55
Before pulling the governor housing, turn the engine so it is on compression on #1 cylinder and the 3/16" hole is lined up in the timing port on the bell housing. That way you will be able to replace the governor if neccessary by following a service manual instructions and not get your timing marks all off. They are not visable on the gears after the front timing cover is installed and you do not want to remove that if you don't have to. Good luck! The governor is removed by taking out the 3 bolts by the oil filler.
rlp
05-12-2010 13:31:22
Something inside of the governer drive must have broken. I think you may have to take the housing off. Take off the distributor and that housing and see if you can see what the problem is. There will be someone else that knows more than me along to help.
Allen L
05-12-2010 17:59:01
Re: CASE SC GOVERNOR in reply to rlp, 05-12-2010 13:31:22
I will take the cover off and see is there is gear problems. I waw hoping it may be something simple but most things never are. thanks again
rlp
05-12-2010 10:59:24
Can you take the distributer out and look in the hole and see the gear? Maybe it is bad and ruined the new gear on the distributer.
Allen L
05-12-2010 12:40:00
Re: CASE SC GOVERNOR in reply to rlp, 05-12-2010 10:59:24
Rip, thanks for the come back, The distributor seems fine and turns. Just can't figure why the governor is locked up, It seems a big job to pull the governor housing to take a look am I right?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
