Company Logo Shop Now
CASE 1830 Uniloader Hub Axle Spline is NOT stripped!
adam.neusbaum
04-22-2010 18:42:20
Before work this morning I removed the front axle and hub assembly to see the splines are great on both the sprocket and axle. Tonight I removed the back axle assembly and they also look fine. Master link coming apart? 3 chains in there, I guess I can only rotate them around to inspect the linkages to be sure, I better get some rubber gloves. Lastly could it be the Cluster sprockets? I think they are all keyed & rotate together, it seems that if one of the little sprockets down there will rotate independantly then that's my problem solved because they should only move when the hydraulic pump rotates. Thanks for writing- Adam
Today's Featured Article - ... [Read Article]
Latest Ad: Single front wheel assembly for 18-27 hart par [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
Binary file (standard input) matches
