Case Tractors Discussion Forum |
CASE 1830 Uniloader Hub Axle Spline stripped?
Author |
[Modern View] |
adam.neusbaum
04-21-2010 20:02:38
Skid steer is heading straight forward then lets go right>>>> pulling back on my right control lever & suddenly hear this loud: run-away clicking coming from one of the axle areas. Both drive chains on the RHSide were extremely loose but I honestly think it"s something more like a stripped out axle spline. Any thoughts please? Also, without paying out $500 where would I get a replacement Drive Axle Hub assembly?
Cas
04-22-2010 16:19:02
Re: CASE 1830 Uniloader Hub Axle Spline stripped? in reply to adam.neusbaum, 04-21-2010 20:02:38
I have an 1845 that did something similar. Did a bunch of mental acrobatics and it turned out to be a master link coming apart. I hope you are as lucky.
adam.neusbaum
04-22-2010 18:42:20
CASE 1830 Uniloader Hub Axle Spline is NOT stripped! in reply to Cas, 04-22-2010 16:19:02
Before work this morning I removed the front axle and hub assembly to see the splines are great on both the sprocket and axle. Tonight I removed the back axle assembly and they also look fine. Master link coming apart? 3 chains in there, I guess I can only rotate them around to inspect the linkages to be sure, I better get some rubber gloves. Lastly could it be the Cluster sprockets? I think they are all keyed & rotate together, it seems that if one of the little sprockets down there will rotate independantly then that's my problem solved because they should only move when the hydraulic pump rotates. Thanks for writing- Adam
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
