Author |
[Modern View] |
Brad Osteen
04-20-2010 17:33:33
I have a 1945 Case LAI Military. Does anyone know how many of these tractors were built. Also, where can technical info on this tractor (i.e. horsepower, cubic inches, or any basic info). I am beginning a restoration and any info would be helpful.
mdhammer
06-20-2010 18:39:33
Re: LAI Military in reply to Brad Osteen, 04-20-2010 17:33:33
I am looking for a Case LAI Military =- do you know where I can buy one?
Brad Osteen
04-22-2010 14:47:11
Paul, the tractor was bought out of North Carolina, but is now in South Carolina.
Brad Osteen
04-23-2010 12:10:01
Re: LAI Military in reply to Brad Osteen, 04-22-2010 14:47:11
I saw today where it said Charlotte Division on the tag
Paul f
04-23-2010 17:41:45
Re: LAI Military in reply to Brad Osteen, 04-23-2010 12:10:01
Brad: Interesting info. Charlotte Douglas Airport was Morris AAF in WW2, but is now home to an AFNG base collocated with the airport It was named Douglas airport in 1954 so maybe your LA got a new data plate to show the new name of the airport.
El Toro
04-22-2010 05:48:56
They used Case tractors at Aberdeen Proving Ground used for pulling large artillery weapons to and from the firing range. They had dual rear wheels and they may have had a road gear since they could travel at a very good speed. This was back in 1951 when I went to work for the Army. Got drafted in 1953. Hal
Brad Osteen
04-21-2010 16:11:25
It has tags on it with Douglas Air Force Base stamped on it. There is a hint of o.d.green paint and a little hint of yellow paint in a few places.
Paul f
04-22-2010 06:17:47
Re: LAI Military in reply to Brad Osteen, 04-21-2010 16:11:25
Brad: There were 2 Douglas Army Airfields in WWII One in AZ on the Mexican Border and one in Georgia Where is the tractor now?
Walt Davies
04-21-2010 13:51:22
They just over 1400 in 1945. The tractor is just an LA with some changes to grill and some other parts of the body. It has 403 4 cylinder gas engine. All of the engines and running gear from an LA will fit. If its military see whether it is Army or Navy to see what color it was painted. Walt
Tom Railsback
04-21-2010 14:01:02
Re: LAI Military in reply to Walt Davies, 04-21-2010 13:51:22
Walt, That total of 1407 is for all LAI series. There is no distinction between military (LAIM) and nonmilitary (LAI) unless Brad goes to Racine and goes through all the build cards.
John D.H.
04-20-2010 18:15:47
There were 6125 built. Rated about 52HP.
