Best way to put a wider front tire on a 530
atlarge54
This tractor is a 530 when I look for parts even though it says it's a 580ck by the numbers. The front tires are 7.50 x 16. I'd like to get a bit wider footprint in front for softer ground. The FEL on this tractor sure seems to make the front end heavy. With the rims and tires on it now there's only about 1/2" clearance between the inside of the tire and the steering arm. What should I be looking for and what should I expect to spend?
You will need a deeper dish rim 15 in and a set of 9.5lx15 or an 11lx15 to get the foot print you want and to keep the same hight as the 7.50x16. I got a new set of 9.5lx15 last year for $95 each, the rims used $20 each. They do make a big diffrence on a tractor with a loader. Hope this helps. Bandit
