case 450 wont move
ddipaolo
New User
hello. I have a case 450 dozer that will not move after it has been shutoff while parked facing uphill. i have to disconnect pump feed hose and fill with oil, blah blah blah. what the hecks causing this? and ideas would be appreciated. thanks
Check your complete suction run from the bottom of the transmission housing for loose clamps or a damaged suction hose. I have seen the filter housing worked loose on the threads where the suction filter mounts to the front of the firewall if its that style, later units had the filter under the floorboards. If all checks out it would indicate that your charge pump is getting weak. . mEl
In addition to all that mEl said ,rather
than the pump being bad , it may be the
shaft seal in the pump,much cheaper than
a pump. Have had that trouble in the early
1000 series case crawlers. 450 usually has
suction hose trouble , either leak or inner
lining coming loose.
george
Thanks guys, i will get under her and see if i can find anywhere she might be sucking air. Its starting to be a pain having to back uphill to park. Dennis
