Case Tractors Discussion Forum |
Hydraulic pump is likely good
Author |
[Modern View] |
Roger (mi)
04-05-2010 19:41:49
If the hydraulics worked well before you split the tractor at the bell housing, your problem is there. As mentioned above, if the hollow shaft that splines into the clutch plate that drives the hydraulic pump has bent the clutch plate during forced assembly, the hydraulic pump will NOT turn. You'll need to split it again at the bell housing to correct the problem.
Mike5
04-06-2010 07:08:15
Re: Hydraulic pump is likely good in reply to Roger (mi), 04-05-2010 19:41:49
Please see my response/question on 4/6 Thanks so much!
Roger (mi)
04-06-2010 19:19:03
You'll need to pull the torque tube ctop cover in reply to Mike5, 04-06-2010 07:08:15
The drive gear for the hydraulic pump and the pump itself are under the top torque cover. In fact, the hydraulic pump is actually attached to that cover. Had a case once where a small ball bearing was sucked up in the hydraulic pick up tube and broke the hydraulic pump. By pulling the torque tube top cover, you'll discover the problem. Just another point. With the tractor running, move one of the remote control levers. It the motor doesn't slow slightly, there is no hydraulic pressure.
Mike5
04-07-2010 17:43:07
Re: You'll need to pull the torque tube ctop cover in reply to Roger (mi), 04-06-2010 19:19:03
According to all the documentation I can find, my tractor (Hyd pump) does not have a pickup tube. According to my CASE Shop Manuel and the Case Parts Catalog (breakdown) for a 430 Series Case Ag & Utility Tractor (s/n prior to 8262800), a pick up tube was on the earlier dry clutch models. My Hyd pump is actually splined onto the main shaft that runs from the clutch through the torque tube. When you refer to the torque tube top cover, are you refering to the Hyd control valve assembly that sets directly under the fuel tank? My plan is to pull Hyd control valve assembly off of the top of the torque tube to see if I find the problem. Really appreciate your help and recommendations! Note: My tractor is a 440 CK s/n 8244359 - 1964 Model Mike
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
