Following the replacement of the transmission shaft (split the tractor), The three point hydraulics do not work (no fluid flow). The hydraulic fluid level is completely full. My 1964 440CK does not have the engagement mechanism as seen the the picture provided by Joe (Wa). From what I have read, this was on the earlier models.
Ran the tractor again today and could not get the three point hydraulics to work. It"s just not picking up the fluid from the torque tube as it should. Even the new filter is still bone dry after 30 minutes of running.
Any "tricks of the trade" would be appreciated!
I believe the hydraulic pump is turning, just not pumping/pressurizing.
Mike
Mike
