1030 pump on a 930
JW
04-01-2010 17:44:42
Will a 1030 injection pump work on a 930? I know everything will bolt up correctly but will it run okay?
mEl
04-02-2010 04:03:40
 Re: 1030 pump on a 930 in reply to JW, 04-01-2010 17:44:42
It will bolt on and run ok. You will not see drastic increases in horsepower. Without the pump numbers I do not know if the plunger size is different or not but the powercell engine does not handle extra fuel as well as a direct injection so if your present pump is working well I'd not spend the effort to change it. If the fuel screw is changed on your present pump it can deliver all the fuel that engine can handle and I have had customer units come into the shop that were overfueled to the point where I have gained horsepower by cutting the fuel back. If your goal is to replace a faulty 930 pump with a good 1030 one, by all means go ahead, if you are looking for a real performance boost, if the 930 pump is good it will overfuel the engine if adjusted properly, what is your goal?. mEl
JW
04-02-2010 04:58:29
 Re: 1030 pump on a 930 in reply to mEl, 04-02-2010 04:03:40
The pump on the 930 is getting bad.
