Recently inherited a I am told Case 530. Gas engine. Has an alternator but I do not know what they came with originally. Need help to identify this tractor. Lable plate on dash is gone. Does not have a tool box. I am a farmall guy. Who can tell me how to figure out what type of tractor this is and how to determine the serial number. Thanks for any help I can get.
Re: Case 530 Serial Number in reply to Robert Laurin, 03-31-2010 18:25:09
Robert
If the serial number plate on the right side panel is gone, this group could help you narrow down to the approximate year with some pictures and/or some more information. Sorry about the Farmall affliction....thats a hard burden to bear, and I hear it's nearly incurable :)......
Does your 530 have:
1. An Eagle Hitch or a 3-point hitch?
2. a Triple Range or Dual Range transmission?
3. Hydrostatic power steering?
4. a cluster gauge (6 gauges under one glass) or individual gauges in the dash?
5. Is the rear axle flanged or is it adjustable with a keyway and a clamp-on hub?
6. Do your rear fenders connect to platforms (where your feet rest), or are they separate and distinct from the platforms?
Robert, Serial number plate will be on the dash if its a 430. Two rivet holes if its missing. Serial number plate on a 530 will be on the side tin which covers the bottom half of the gas tank from the chrome strip down. If the tin is gone, the serial number is gone.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
Looking for two coulters and mounting brackets for a JI Case centennial plow
[More Ads]
