Recently split my tractor to replace the synchronizer. After re-assembling everything including replacing the hydraulic filter, the three-point does not work - not hydraulic pressure out of the filter housing fitting going to the three point. All lines are connected and the hydraulic fluid is full in both sections of the tractor.
Does the pump need to be bled to get this going? If so, how is this done?
The three point was fully operational prior to splitting the tractor.
Appreciate any recommedations.
Mike
Mike
