970 brakes
brandon56
03-09-2010 22:17:28
I took the brake lines apart on my 970 because I pulled the top cover off my transmission. Now I cant get the brakes bled. When the pedal is pumped no pressure ever builds, all I get is air bubbles. What would cause this problem? I was thinking maybe the brake valve under the dash. How do I fix this problem?
mEl
03-10-2010 04:32:32
 Re: 970 brakes in reply to brandon56, 03-09-2010 22:17:28
[quote="brandon56"](reply to post at 23:17:28 03/09/10) If the pedal adjustment is correct and the nylon clip is good on the control rod at the brake valve rod you DO NOT NEED to pump the brakes, just start the engine, loosen the bleeder and it will self bleed as sump pressure is sufficient to bleed them out, better remove the bleeders and check them to see that they are open, had one plugged with crap on mine. mEl
