Anonymous-0
On my Case 430 my hydraulics appear to be weak. I have taken the lifting pistons off my bucket and replaced all the O rings. Prior to replacing the O rings I installed a gauge to measure the pressure in the line. The pressure in the line is constant prior to changing the O rings and after. I have been using the tractor off and on for approximately 6 weeks, the gauge is constantly running at 500 lbs. when the hydraulic is engaged the gauge shows approximately 500 lbs. Yesterday when lifting the bucket my pressure was 500 lbs. but when the bucket was lifted all the way the pressure shot up to 1000 lbs. it has never gone this high before. Turn the tractor off and the bucket will gradually come down as time passes. The hydraulics on the back with the snow blower on it will remain up and not gradually fall down over time. I have a leak somewhere, is there any way I can determine where it is, or do I just tear everything apart and repair it? I understand my pressure should be approximately 2000 lbs. I am a little short. How do I correct my problem? Any help or suggestions would be greatly appreciated. Fellows take care of yourselves and have a great safe day. Barney
