Case Tractors Discussion Forum |
1962 Case 530
Author |
[Modern View] |
Richard Andrews
02-28-2010 05:31:42
I recently got a 1962 Case 530 loader,I went to use it yesterday and the right rear wheel is locked up.Any ideas,Left side works fine
tom stanley
02-28-2010 06:34:18
Re: 1962 Case 530 in reply to Richard Andrews, 02-28-2010 05:31:42
the brake has gotten moisture in it you need to take it apart and repairs should be as simple as clean up also check your rear end fluid make sure water is not present their also as a shifter boot or top cover gasket leak will cause this also good luck Tom
Richard Andrews
02-28-2010 06:38:58
Re: 1962 Case 530 in reply to tom stanley, 02-28-2010 06:34:18
Thanks,its very possble,I was moving snow last weekend before it was parked in the garage which isn't heated.Thanks again
curtis larson
02-28-2010 06:32:12
The ball ramps are rusty in the brakes. Cheap fix. Also check the cross shaft for the clutch.It needs lub. This can be done from the out side. When you push the clutch some times it will apply the left brake. But the total lock up is most likely from rust.
Richard Andrews
02-28-2010 06:44:32
Re: 1962 Case 530 in reply to curtis larson, 02-28-2010 06:32:12
Thanks,I was moving snow last weekend before I parked it,its very possible.Thanks Again
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
