Re: 400 hydraulics- Need help
Patrick Tercho
04-11-2000 03:44:04
Ron-
Relief valve should be a free sliding fit, needle nose should get it out for you. Excessive play will cause low pressure, if it is solid shut, I'm guessing it blew a seal in the pump or valve body somewhere because relief didn't let go like it should have. You should still be able to get parts from Case dealer, there was a mod on the relief valve cap and springs after tractor was made.
Pat
