Parting out 1030
Anonymous-0
This tractor had a junk block in it and someone else wanted some pieces so I tore it down. My question is, it has really a nice hood,nose piece,grills and other various things but do them grills fit anything other than a 1030 and if so, what? What is that stuff worth? Thanks
Nice grills bring $50 a piece on ebay. Bought a hood in the local junkyard a year ago for $50.
Tin work and many other parts fit 730/830/930 series. Especially comfort king models. Where are you located I would be interested in a couple parts if you are close.
The hood front end and screens only fit the 1030 correctly. The hood and front end each are 1.5 in longer than the 930.
i would be interested in the fuel tank if it doesnt have any dents in it. Where in Iowa are you located? I travel through there from time to time and could pic up the tank possibly.
thanks
john
I need the draft sensing link from underneath the rear end, has a big cast iron hook on one end.
I also need that little strap "lever" that is down by the hydraulic levers on the RH side next to the seat and connects to a lever on top of the transmission. What year is it and how are the engine pulleys, mainly fan and power steering?
I have a 68 orange column and the power steering pulley is almost square, fan is usuable
