Re: 1970 580 ck hour meter cable location in reply to jesse I, 01-31-2010 15:27:19
On our 480B is on the side of the engine. It looks like the stud of a coolant temp sensor almost. When the engine is running you will see it spinning around. (its about in the middle of the engine on the side of the block on the right side when sitting in the operating seat facing forward)
The location would normally be on the distributor main shaft below the distributor body. However, not all distributors had this option. It may be that your distributor was changed at some point with a model not having the right angle drive option. Hope this helps. ap61
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
