Anonymous-0
'77 1070 appears to have a suction leak. I have a loader plumbed to the to remotes. Seems a little weak. Hoses pulse and make noise like air in the oil. Inching pedal is grabby at anything above idle. Brakes are grabby. Power shift seems to shift fine. Power steering is fine. I had the pto housing off about 10 hrs ago to replace the pto brake. Rolled pin had fallen out (hole in the shaft worn out). Tractor was fine until just the past hour or so. Thought maybe I had cut the O-ring on the suction pipe but it is fine. Only thing I can think of is the suction pipe is leaking. Any place else to look? Not looking forward to pulling the pto housing again. I find it hard to believe that the pipe would be loose in 10 hours. Oil level is fine. Any ideas?
