2470 fuel leakoff
Bill Thurman
12-28-2009 19:27:44
I have a 2470 that if it sets for a couple of days the fuel will leak off and it won"t start till you pump it back up, will the poppets in the fuel pump cause this, where do I need to look, Thanks
dwag
12-30-2009 18:29:34
 Re: 2470 fuel leakoff in reply to Bill Thurman, 12-28-2009 19:27:44
Along with faulty primer, especially the newer "umbrella type", the brass return line tee at top,side,front of pump could have a leaking check valve, which is what I find most often. Tee is very $$$$ thru Caseih. Have gotten replacements from salvage and Spencer Diesel in Iowa.
dboll
12-29-2009 05:38:05
the hand primer pump on the injection pump has nylon disks in it that act as a check valve and will allow bleedback, over 10 years ago I dealt with the same problem on a 4490.
