Case Tractors Discussion Forum |
engine block serial number
Author |
[Modern View] |
Frank Vantacich
12-07-2009 16:21:33
According to the service manual the serial number for a VAC engine block should be located on the distributor side of the block. I can not find it there or any place else on the block. Any suggestions?
1031D
12-08-2009 22:16:29
Re: engine block serial number in reply to Frank Vantacich, 12-07-2009 16:21:33
My 1944 VAC had an engine serial number, I will have to post a picture.
Nick@KY
12-08-2009 04:48:42
On the early engines without the raised vertical pad I have seen the number stamped horizontaly on the distributor side of the block at the rear near the head. Nick
VACLee
12-07-2009 20:23:08
Up through mid 1947 Continental built the engines to Case specs. When Case took over production at their engine plant they started putting the numbers on a raised pad behind the oil filter. Prior to that they were not numbered. Yours is an early model. The most noticable difference is the mount for the governor rod. Yours will have a pad with the 2 studs very close together, whereas the later ones have a wider pad. Several of the bolt-on pieces are different such as the linkage and the front cover. The later style did not have the access cover to the governor. The manifold changed at that time also from a one piece to a two piece with a different elbow. The early manifold sets much closer to the block which meant the air filter housing is different. Lee
VACLee
12-08-2009 12:50:49
Re: engine block serial number in reply to VACLee, 12-07-2009 20:23:08
Forgot to mention that these numbers will be engine serial numbers and not actual tractor serial numbers. They will not always tie back to an exact year model.
Nedd
12-07-2009 18:52:52
VAC were built at the Rock Island plant and did not have the serial number on the flange like the D, S and L series. The tag is the only thing with it on. There might be some other distinct features for your VAC that will help get close to the correct year. I"m not a VAC expert someone else might be able to help you more.
TimBinWV
12-07-2009 17:04:47
Is it not on the rear flange of the block? It could have been ground off at some point in time.
Frank Vantacich
12-07-2009 19:19:39
Re: engine block serial number in reply to TimBinWV, 12-07-2009 17:04:47
Nope, no serial number on the flange. The only number I could find on the block is a VT149, which is a part number? This number is not in the parts manual.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
