1031 presure cap
A 7 PSI radiator cap is used if the tractor does not have a Tans.Hyd.Oil cooler. If the tractor has a Trans.Hyd.Oil cooler, a 14 Psi cap is used.
I believe the 1031 model number designates a Geral Purpose Tractor. These were made the whole time the 1030 Series was produced.
Hope this helps. I have a 1031 that has really been a good tractor for me. Best Wishes !
I fianally found out tis a later tractor and requires the 14# cap case dealer has one for a 1070 which I will goand compare both 451 he said later ones required 14 thanks again let you know if works bob
