Case Tractors Discussion Forum |
1070 reverse
Author |
[Modern View] |
J Heitkemper
11-21-2009 20:04:17
My brother just told me today , That a 1070 powershift should have a lockout disabling 4th range reverse .. My 71'1070 ,will fly in 4th reverse,,, consequently ,I do not use that gear at all, And I feel this gear was locked out in later models only because it was impractical and Dangerous , Brother warned that damage to tranny could result if I frequently used hi range reverse , I say hog-wash ,,..Bottom line is there something wrong with My tractor if it has a working hi speed 4th reverse ??? , Thanx Jim
Superturbodiesel
11-22-2009 23:46:07
Re: 1070 reverse in reply to Don L., 11-21-2009 20:04:17
J Heitkemper said: (quoted from post at 05:04:17 11/22/09) Bottom line... is there something wrong with my tractor if it has a working high-speed 4th reverse? Thanx, Jim |
Absolutely NOT Jim. No harm will occur to your transmission if using "4th reverse". Your brother is WRONG - period. YOU are 100% correct in your saftey assumption as to why Case updated their later production tractors with the 4th reverse "lock-out" in their later built tractors. Traveling in reverse at high speeds can be a recipe for a major disaster. So if you choose to use it, please BE CAREFUL! Probably best you refrain and never use it - for everyone's saftey & well-being. Happy reversing! ~AJ
mEl
11-22-2009 12:35:22
Re: 1070 reverse in reply to J Heitkemper, 11-21-2009 20:04:17
J, your 1070 shoud never "fly" into reverse, in fact it should not go into reverse ever if the clutch is released, the reverse lockout spool will not allow that if all is together correctly. Please post back if you can lever back into reverse without pushing the inching pedal (clutch). If you can it indicates that the selector spool is 1/2 turn out of position and the reverse lockout slot is away from the reverse lockout plunger, a very dangerous situation. Yes, the later 70 series locked out 4th gear in reverse lever position. mEl
J Heitkemper
11-22-2009 19:49:15
Re: 1070 reverse in reply to mEl, 11-22-2009 12:35:22
Thanx mEl, I Must (clutch) in order to get reverse ...I looked at my printed words and realized that it could be misleading ,, My 1070 when placed in 4th range Reverse , Will go very VERY fast backwards , My Brother thinks damage could result if I used that hi reverse Position , Which Is my point of Concern ...Please know ,It will not automatically fall into reverse and take-off backwards unattended ..
mEl
11-23-2009 04:30:45
Re: 1070 reverse in reply to J Heitkemper, 11-22-2009 19:49:15
Thanks for the clarification J. Reverse ps ratio is the same as 3rd ps ratio in any gear so operating the tractor in 4th gear in reverse at full throttle would generate some interesting contol issues LOL. BTW I have inadvertantly ran the ps in reverse on the dyno and can attest that it eats up a few hp till you figure it out, but no hardware failures but the recommendation to not do that stands. mEl
DKase
11-21-2009 21:20:04
My 870 is an early one. I do not know how early because the SN tag is AWL. It is early enough so it has the fuel priming pump on the fuel filter. Yes you are right! It will boogie right along in 4th reverse. Good for 4 wheel trailer backing practice. LOL
J Heitkemper
11-22-2009 07:12:59
Re: 1070 reverse in reply to DKase, 11-21-2009 21:20:04
thanx DKase,,,So then My tractor is fine, and some folks just luv to worry me . LOL ... The fuel primer is next to the filter on mine also ,, I have checked the serial#when this 1070 came wandering up the drive a year ago and proved it to be a 1971 build yr.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
