Case Tractors Discussion Forum |
CASE 350B BRAKE BAND ADJUSTMENT PROCEDURES
Author |
[Modern View] |
gsford
11-09-2009 15:19:37
Just bought an '81 350B crawler/loader that had new brake bands installed last year after the dealer took it in on trade. They're out of adjustment now. Can anyone tell me what the adjustment procedures are as there is almost no steering control on this old beauty. Thanks George
mEl
11-09-2009 16:26:34
Re: CASE 350B BRAKE BAND ADJUSTMENT PROCEDURES in reply to gsford, 11-09-2009 15:19:37
There are two adjustments on the 350 series, one external, one internal. When the external adjustments no longer are effective, the rear cover must be removed and the connecting links shortened to renew the external adjustment to effectiveness. Back off the external adjustment so the external arm can rock back toward the rear of the tractor. The band will have to be held up in normal position with a pry off the bottom of the opening to get all the adjustment you can get and still get the pin reinstalled. You will see what I mean when you start working on it. The transmission takes a mineral based oil instead of just gear lube and failure to use it will degrade the lining. If the bands are good the tractor should turn without a lot of effort and I always adjust them so the levers pull back against the seat frame so as to stop lever travel without putting enough pressure on the band to stretch them and ruin them. I have seen many bands stretched to the point of being ruined by people reefing on the levers thinking it helps to turn better. Above all fill the tranny to level with the proper oil. Maybe someone on forum can post a pic of the diff/steering band arrangement so you can see in advance what I'm refering to. mEl
George Shackelford
11-10-2009 08:43:56
Re: CASE 350B BRAKE BAND ADJUSTMENT PROCEDURES in reply to mEl, 11-09-2009 16:26:34
Thanks for the great response on the brake adjustment. I agree a picture of how to adjust the brakes would be very helpful when I tackle the adjustment. I read on another site that most of the brakes are adjusted so the bands wear out on the ends and the center of the bands never get any wear. I wonder how you avoid that? George
mEl
11-10-2009 14:56:47
Re: CASE 350B BRAKE BAND ADJUSTMENT PROCEDURES in reply to George Shackelford, 11-10-2009 08:43:56
You will see that when you get the back off, the pressure points are greatest at the end of the bands cause of how they are anchored. mEl
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
